Guida | Sbrandizzare Zyxel VMG8825-T50K Tiscali
Maybe it could be possible to manually extract the 12-digit code from the 36-digit one. A too simple example: have you tried to check if the 36 digits divided into 3 groups work?
2501000E0900 13009C030490 330691452269
Related topics
https://community.zyxel.com/en/discussion/13070/dx5401-aten-atse
I hadn't tried that, but I just did. Unfortunately, it doesn't work. I tried the codes both separately and combined, but it didn't unlock additional options in the bootloader.
Disponibile il nuovo firmware Zyxel nobrand 5.50(ABOM.8.3)C0
Firmware Release Note:
Codice:
Modifications in V5.50(ABOM.8.3)C0
Base on V5.50(ABOM.8.3)b2 to release V5.50(ABOM.8.3)C0
Modifications in V5.50(ABOM.8.3)b2
Base on V5.50(ABOM.8.3)b1 to release V5.50(ABOM.8.3)b2
[BUG FIX]
1. Zyxel-SI-1506 [Vulnerability] Post-authentication buffer overflow
2. Zyxel-SI-1536 [Vulnerability] Buffer overflow vulnerability in the "traceroute" command
Modifications in V5.50(ABOM.8.3)b1
Base on V5.50(ABOM.8.2)C0 to release V5.50(ABOM.8.3)b1
[BUG FIX]
1. [eITS#231200554][VMG8825-T50K] NAT is not working properly
Aggiornato il primo messaggio.
@atusteno ho chiesto i sorgenti a Zyxel 🤞🏻
E' arrivata la risposta di Zyxel:
8.3C0 is a beta FW for our internal testing purpose, hence we don’t release GPL version
Hereby, I would like to provide you the formal release version 8.2C0.
Per ora l’interfaccia seriale è l'unico modo per passare dalla versione brandizzata Tiscali alla 8.3C0.
Disponibile il nuovo firmware Zyxel nobrand 5.50(ABOM.8.4)C0
Codice:
Modifications in V5.50(ABOM.8.4)C0
Base on V5.50(ABOM.8.4)b1 to release V5.50(ABOM.8.4)C0
[FEATURE ENHANCEMENT]
[BUG FIX]
Modifications in V5.50(ABOM.8.4)b1
Base on V5.50(ABOM.8.3)C0 to release V5.50(ABOM.8.4)b1
[BUG FIX]
1. [CVE-2024-5412][Zyxel-SI-1557][Vulnerability] Unauthenticated
buffer overflow vulnerability in the libclinkc library
2. [CVE-2024-38266,38267,38268,38269][Zyxel-SI-1559][Vulnerability]
Multiple authenticated buffer overflow vulnerabilities
@atusteno ti ho mandato un messaggio privato con i sorgenti del fw 5.50(ABOM.8.4)C0
Zyxel ha pubblicato la nuova versione 5.50(ABOM.8.5)C0 del 13 novembre 2024
Release Note:
Codice:
Modifications in V5.50(ABOM.8.5)C0
Base on V5.50(ABOM.8.5)b2 to release V5.50(ABOM.8.5)C0
[BUG FIX]
Modifications in V5.50(ABOM.8.5)b2
Base on V5.50(ABOM.8.5)b1_D0 to release V5.50(ABOM.8.5)b2
[BUG FIX]
1. [CVE-2024-20018] Improper input validation in wlan driver
2. [CVE-2024-9197][Zyxel-SI-1583][Vulnerability] Buffer overflow and
potential command injection vulnerabilities in VMG3625-T50B
(Medium)
3. [CVE-2024-8748][Zyxel-SI-1576][Vulnerability] Unauthenticated
buffer overflow in VMG8825-T50
Modifications in V5.50(ABOM.8.5)b1_D0
Base on V5.50(ABOM.8.4)C0 to release V5.50(ABOM.8.5)b1_D0
1. [eITS#240701005] Add a new Certificate
[BUG FIX]
1. [eITS#240200700] VMG8825-T50K issue data disconnection and
Multicast IPTV Freezing
@atusteno sono in attesa dei sorgenti da parte di Zyxel, fammi sapere se ti servono ;)
Il VMG8825-T50K dal 30 dicembre 2024 è in EOL
Fine dello sviluppo
Da questa data in poi, non verranno sviluppate nuove funzionalità o miglioramenti. Ci concentreremo solo su questioni critiche che hanno un impatto significativo sulle operazioni aziendali o sulla stabilità del sistema, assicurando che le funzionalità essenziali del sistema siano mantenute.
Fine del supporto per le vulnerabilità
Prima di questa data, le vulnerabilità di sicurezza critiche che potrebbero avere un impatto significativo sulla sicurezza del sistema saranno affrontate. Le build di manutenzione saranno rilasciate per gravi problemi di sicurezza che richiedono attenzione immediata.
