[ 5198.330853] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 5198.337643] br-lan: port 2(wlan1) entered blocking state
[ 5198.342958] br-lan: port 2(wlan1) entered forwarding state
[ 5265.786933] device wlan0 left promiscuous mode
[ 5265.791667] br-lan: port 3(wlan0) entered disabled state
[ 5266.569025] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5266.580835] br-lan: port 3(wlan0) entered blocking state
[ 5266.586171] br-lan: port 3(wlan0) entered disabled state
[ 5266.592137] device wlan0 entered promiscuous mode
[ 5266.597485] br-lan: port 3(wlan0) entered blocking state
[ 5266.602830] br-lan: port 3(wlan0) entered forwarding state
[ 5266.997533] br-lan: port 3(wlan0) entered disabled state
[ 5273.657621] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 5273.664263] br-lan: port 3(wlan0) entered blocking state
[ 5273.669614] br-lan: port 3(wlan0) entered forwarding state
[11784.064910] mtk_soc_eth 1e100000.ethernet eth0: port 2 link down
[13323.646053] device wlan0 left promiscuous mode
[13323.650754] br-lan: port 3(wlan0) entered disabled state
[13325.818185] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[13325.878333] br-lan: port 3(wlan0) entered blocking state
[13325.883909] br-lan: port 3(wlan0) entered disabled state
[13325.889973] device wlan0 entered promiscuous mode
[13332.938831] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[13332.945895] br-lan: port 3(wlan0) entered blocking state
[13332.951215] br-lan: port 3(wlan0) entered forwarding state
Ciao, strano… dovrebbe essere attiva di default…smanettando un po’ mi sono reso conto che non avevo ma WMM mode attiva
Gli unici driver funzionanti erano quelli di Nossiac che lavora in Mediateke’possibile mettere i driver xiaomi o qualche altro driver funzionante ?
Ti consiglio di postare nel forum OpenWrt la tua configurazione wireless.Comunque hai qualche consiglio?
cat /etc/config/wireless
Ciao, purtroppo no…Tutti gli hardware dove si installa openwrt (tolti quelli 4/32 warning) supportano la rete mesh?
In teoria con B.A.T.M.A.N. avresti una maggiore compatibilità ma se non hai un minimo di esperienza rischi di impazzireassuming that there is hardware/driver support
Sure! Check the attachment:If not, would you be so kind as to do it if you can ?
Thank you so much. You’re the best!Hello Gilles
openwrt-19.07.5-ramips-mt7621-xiaomi_mir3g-Gilles.zip
No mi dispiace, prima ho sempre ripristinato il firmware originale.hai per caso informazioni su come potrei fare per passare da openwrt a padavan senza passare per lo stock? Grazie mille
No mi piace il rischioTu usi breed?
Non puoi perché usa delle partizioni diverse.non sono riuscito a capire è perché da breed posso installare padavan e firmware originale senza problemi ma non openwrt.
Upgrade OpenWRT and reinstalling packages | TechFindings usa questa guidaVorrei però non farlo ogni volta!
Mi indicheresti una guida da seguire per creare il firmware di upgrade compilato già con tutti i pacchetti che utilizzo, un po’ quello che hai fatto tu nel secondo post, così con la nuova versione, prendo il firmware di upgrade e mi metto dentro già tutti i pacchetti che mi interessano.
Attendo tue direttive!
