Router TL-MR3420 e Huawei E353
ottimo, adesso vedo se si puo’ avere quello dell’altro utente (dovrebbe averlo spedito a Admin compilando il modulo…).
non credo che il brand cambi vendor e product id (12d1_14fe), per questo mi par strano!
ti faccio sapere!
Ecco il log della E353 TIM inviato da Damiano (grazie 😉 )
Codice:
# 			       TL-MR3420  System Log
# Time = 2011-08-14 11:50:59 6012s
# H-Ver = MR3420 v1 00000000 : S-Ver = 3.12.19 Build 110617 Rel.39329n
# L = 192.168.1.1 : M = 255.255.255.0
# 3G : 3G = 109.52.xxx.xxx : M = 255.255.255.255 : G = 109.52.xxx.xxx
1st day 00:00:04	 OTHER     	INFO   	System started
1st day 00:00:08	 DHCP      	NOTICE 	DHCP server started
1st day 00:00:08	 SECURITY  	INFO   	PPTP Passthrough enabled
1st day 00:00:08	 SECURITY  	INFO   	L2TP Passthrough enabled
1st day 00:00:08	 SECURITY  	INFO   	IPSEC Passthrough enabled
1st day 00:00:08	 SECURITY  	INFO   	FTP ALG enabled
1st day 00:00:08	 SECURITY  	INFO   	TFTP ALG enabled
1st day 00:00:08	 SECURITY  	INFO   	H323 ALG enabled
1st day 00:00:09	 SECURITY  	INFO   	RTSP ALG enabled
1st day 00:00:29	 3G        	INFO   	3G Modem vendorID: 0x12d1; productID: 0x1446
1st day 00:00:30	 3G        	INFO   	3G Modem vendorID: 0x12d1; productID: 0x1446
1st day 00:00:34	 3G        	INFO   	Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:00:39	 DHCP      	NOTICE 	DHCPS:Recv DISCOVER from 00:21:6B:07:EB:7E
1st day 00:00:40	 3G        	INFO   	3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:00:40	 DHCP      	NOTICE 	DHCPS:Send OFFER with ip 192.168.1.100
1st day 00:00:40	 DHCP      	NOTICE 	DHCPS:Recv REQUEST from 00:21:6B:07:EB:7E
1st day 00:00:40	 DHCP      	NOTICE 	DHCPS:Send ACK to 192.168.1.100
1st day 00:00:41	 3G        	INFO   	3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:00:44	 DHCP      	NOTICE 	DHCPS:Recv INFORM from 00:21:6B:07:EB:7E
1st day 00:01:46	 3G        	INFO   	Main interface_index[0] = -1
1st day 00:01:46	 3G        	INFO   	Vice interface_index[1] = 0
1st day 00:01:46	 3G        	INFO   	Vice interface_index[2] = 3
1st day 00:01:46	 3G        	INFO   	Line:926 cmd: modem_scan -d /dev/ttyUSB0 -f "chat -S -V -f /tmp/script" > /tmp/modem_info 2>&1
1st day 00:01:49	 3G        	INFO   	Line 944:
1st day 00:01:49	 3G        	INFO   	Line 944: 11.810.09.10.192
1st day 00:01:49	 3G        	INFO   	Line 944: OK
1st day 00:01:49	 3G        	INFO   	Line 944: ATZ
1st day 00:01:49	 3G        	INFO   	Line 944: AT+CGMM
1st day 00:01:49	 3G        	INFO   	Line 953: E353
1st day 00:01:49	 3G        	INFO   	getModemParamByScript 1099 Chip type = 1
1st day 00:01:49	 3G        	INFO   	get_modem_info_file 140 getModemParamByScript return valid type = 1
1st day 00:01:49	 3G        	INFO   	Line:926 cmd: modem_scan -d /dev/ttyUSB0 -f "chat -S -V -f /tmp/script" > /tmp/modem_info 2>&1
1st day 00:01:51	 3G        	INFO   	Line 944:
1st day 00:01:51	 3G        	INFO   	Line 944: E353
1st day 00:01:51	 3G        	INFO   	Line 944: OK
1st day 00:01:51	 3G        	INFO   	Line 944: ATZ
1st day 00:01:51	 3G        	INFO   	Line 944: AT+CSQ
1st day 00:01:51	 3G        	INFO   	Line 978: +CSQ: 1,99
1st day 00:01:51	 3G        	INFO   	Line 944: OK^M
1st day 00:01:51	 3G        	INFO   	Line 944: Serial connection established.
1st day 00:01:51	 3G        	INFO   	Line 944: Serial link disconnected.
1st day 00:01:51	 3G        	INFO   	getModemParamByScript 1099 Chip type = 1
1st day 00:01:51	 3G        	INFO   	get_modem_info_file 155 getModemParamByScript return valid type = 1
1st day 00:01:51	 3G        	INFO   	Line:926 cmd: modem_scan -d /dev/ttyUSB0 -f "chat -S -V -f /tmp/script" > /tmp/modem_info 2>&1
1st day 00:01:54	 3G        	INFO   	Line 944:
1st day 00:01:54	 3G        	INFO   	Line 944: +CSQ: 1,99
1st day 00:01:54	 3G        	INFO   	Line 944: OK
1st day 00:01:54	 3G        	INFO   	Line 944: ATZ
1st day 00:01:54	 3G        	INFO   	Line 944: AT+CPIN?
1st day 00:01:54	 3G        	INFO   	Line 1024: +CPIN: READY
1st day 00:01:54	 3G        	INFO   	Line 944: OK^M
1st day 00:01:54	 3G        	INFO   	Line 944: Serial connection established.
1st day 00:01:54	 3G        	INFO   	Line 944: Serial link disconnected.
1st day 00:01:54	 3G        	INFO   	getModemParamByScript 1099 Chip type = 1
1st day 00:01:54	 3G        	INFO   	get_modem_info_file 170 getModemParamByScript return valid type = 1
1st day 00:01:54	 3G        	INFO   	get_modem_info_file 185 Return chip type = 1
1st day 00:01:54	 3G        	INFO   	3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:01:54	 3G        	INFO   	USB modem is ready
1st day 00:01:55	 PPP       	NOTICE 	Standard authentication.
1st day 00:01:55	 3G        	INFO   	Run 3G dial cmd: pppd /dev/ttyUSB0 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:01:56	 DHCP      	NOTICE 	DHCPS:Recv INFORM from 00:21:6B:07:EB:7E
1st day 00:01:59	 PPP       	INFO   	sent [LCP Req mru=1480 asyncmap=0x0 magic=0xc96c484b]
1st day 00:01:59	 PPP       	INFO   	rcvd [LCP Req asyncmap=0x0 auth=chap-MD5 magic=0x2f97880 pcomp accomp]
1st day 00:01:59	 PPP       	INFO   	sent [LCP Rej pcomp accomp]
1st day 00:01:59	 PPP       	INFO   	rcvd [LCP Ack mru=1480 asyncmap=0x0 magic=0xc96c484b]
1st day 00:01:59	 PPP       	INFO   	rcvd [LCP Req asyncmap=0x0 auth=chap-MD5 magic=0x2f97880]
1st day 00:01:59	 PPP       	INFO   	sent [LCP Ack asyncmap=0x0 auth=chap-MD5 magic=0x2f97880]
1st day 00:01:59	 PPP       	INFO   	rcvd [LCP DiscReq magic=0x2f97880]
1st day 00:01:59	 PPP       	INFO   	rcvd [CHAP Challenge (d49cf3390440bda8281db620de3d3494), name = "UMTS_CHAP_SRVR"]
1st day 00:01:59	 PPP       	INFO   	sent [CHAP Response (3d63a924c5bd2fcab74db9a0ea2171ca), name = ""]
1st day 00:01:59	 PPP       	INFO   	rcvd [CHAP Success ""]
1st day 00:01:59	 PPP       	INFO   	sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0 dns1=0.0.0.0 dns3=0.0.0.0]
1st day 00:02:00	 PPP       	INFO   	rcvd [IPCP Nak dns1=10.11.12.13 dns3=10.11.12.14]
1st day 00:02:00	 PPP       	INFO   	sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0 dns1=10.11.12.13 dns3=10.11.12.14]
1st day 00:02:01	 PPP       	INFO   	rcvd [IPCP Req]
1st day 00:02:01	 PPP       	INFO   	sent [IPCP Nak addr=0.0.0.0]
1st day 00:02:01	 PPP       	INFO   	rcvd [IPCP Rej compress VJ 0f 01]
1st day 00:02:01	 PPP       	INFO   	sent [IPCP Req addr=0.0.0.0 dns1=10.11.12.13 dns3=10.11.12.14]
1st day 00:02:01	 PPP       	INFO   	sent [IPCP Ack]
1st day 00:02:01	 PPP       	INFO   	rcvd [IPCP Nak addr=217.202.xxx.xxx dns1=213.230.155.10 dns3=213.230.129.10]
1st day 00:02:01	 PPP       	INFO   	sent [IPCP Req addr=217.202.xxx.xxx dns1=213.230.155.10 dns3=213.230.129.10]
1st day 00:02:01	 PPP       	INFO   	rcvd [IPCP Ack addr=217.202.xxx.xxx dns1=213.230.155.10 dns3=213.230.129.10]
1st day 00:02:08	 3G        	NOTICE 	3G connected
1st day 00:16:21	 DHCP      	NOTICE 	DHCPS:Recv REQUEST from 00:21:6B:07:EB:7E
1st day 00:16:21	 DHCP      	NOTICE 	DHCPS:Send ACK to 192.168.1.100
1st day 01:00:39	 PPP       	ERROR  	User request
1st day 01:00:39	 PPP       	ERROR  	LCP down
1st day 01:00:39	 PPP       	WARNING	LCP down
1st day 01:00:39	 PPP       	INFO   	sent [LCP TermReq]
1st day 01:00:39	 PPP       	INFO   	rcvd [LCP TermAck]
1st day 01:00:43	 3G        	WARNING	3G max idle time is up
1st day 01:14:39	 DHCP      	NOTICE 	DHCPS:Recv REQUEST from 00:21:6B:07:EB:7E
1st day 01:14:39	 DHCP      	NOTICE 	DHCPS:Send ACK to 192.168.1.100
1st day 01:14:40	 PPP       	NOTICE 	Standard authentication.
1st day 01:14:40	 3G        	INFO   	Run 3G dial cmd: pppd /dev/ttyUSB0 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 01:14:44	 PPP       	INFO   	sent [LCP Req mru=1480 asyncmap=0x0 magic=0x2b869945]
1st day 01:14:44	 PPP       	INFO   	rcvd [LCP Req asyncmap=0x0 auth=chap-MD5 magic=0x33c1274 pcomp accomp]
1st day 01:14:44	 PPP       	INFO   	sent [LCP Rej pcomp accomp]
1st day 01:14:44	 PPP       	INFO   	rcvd [LCP Ack mru=1480 asyncmap=0x0 magic=0x2b869945]
1st day 01:14:44	 PPP       	INFO   	rcvd [LCP Req asyncmap=0x0 auth=chap-MD5 magic=0x33c1274]
1st day 01:14:44	 PPP       	INFO   	sent [LCP Ack asyncmap=0x0 auth=chap-MD5 magic=0x33c1274]
1st day 01:14:44	 PPP       	INFO   	rcvd [LCP DiscReq magic=0x33c1274]
1st day 01:14:44	 PPP       	INFO   	rcvd [CHAP Challenge (7c9d3f9a00877cc6ce76831978dbec05), name = "UMTS_CHAP_SRVR"]
1st day 01:14:44	 PPP       	INFO   	sent [CHAP Response (8eeb3fa6fb1fd0f2e3e2a01198982ca7), name = ""]
1st day 01:14:44	 PPP       	INFO   	rcvd [CHAP Success ""]
Come potete vedere hanno diverso Product ID quindi niente :-/
infatti!! è quello il problema 😦
a questo punto o provi a sbrandizzarla (non chiedermi come), oppure a creare il file BIN con la guida per l’usb sniffer che trovi nel primo post…
che sfortuna pero’…
scusate se non ho risposto prima,comunque ritornando a noi la guida l’ho seguita,ho fatto un paio di tentativi ma i file che vengono generati quando li vado a caricare il router risponde con error 50002 non sò se sbaglio qualcosa ma credo di aver seguito fedelmente le indicazioni,per quanto riguarda il brand saprei come fare ma la chiavetta è nuova quindi sicuro che mi gioco la garanzia forse faccio meglio a venderla e procurarmi magari una E1820 di cui ho sempre sentito parlar bene
Saluti a tutti
un passaggio con il programma sniffer l’ho sbagliato quindi appena posso riproverò
Grazie Nebbia:)
Ciao a tutti
ciao a tutti
posso sapere come debbo procedere per uttilizare la pennina arancione della wind
con questo router tp-link TL-ML3420
la penna e quella da voi menzionata piu volte la Huawei E353
come avrai letto alla pagina precedente la penna della wind non andava… è diversa da quella TIM che la casa indica come compatibile!
bisognerebbe provare con il programma per creare file BIN che trovi nel primo post del topic in rilievo.
Aggiungo che la e353 della 3 è molto diversa da quella TIM infatti una volta levato il coperchio per mettere la SIM si legge benissimo che il modello esatto è e353s-2 e purtroppo non è compatibile.
Se non me la cambiano con la e367 provo a fare il .bin 😉
Ci sono troppe versioni di questa internet key, il problema è che nella confezione c’è scritto sempre e353 :-/
posta il log, magari è uguale a quella wind! ^^
No è diverso, ma se non ricordo male ho letto (sempre in questo forum) che la e353 Wind funziona con il firmware di giugno (quello ritirato dal sito tplink).
no basta che leggi qui alla 3a pagina 😦
Allora sicuramente il post che ho letto si riferiva ad un altra versione, ecco alcune cose interessanti che ho scoperto con putty (e353s-2 H3G)
Codice:
^SYSCFG: (2,13,14,16),(0-3),((2000000400380,"GSM900/GSM1800/WCDMA900/WCDMA2100"),(280000,"GSM850/GSM1900"),(3fffffff,"All bands")),(0-2),(0-4)
OK
^GETPORTMODE: TYPE: WCDMA: huawei,MDM:0,NDIS:1,DIAG:2,PCUI:3,CDROM:4,SD:5
OK
E’ anche UMTS a 900Mhz
Devo riuscire a disattivare cdrom e sd, il programma per creare il file .bin non funziona con seven 64bit 😦
ero rimasto al punto in cui in italia non era usato da nessun operatore…
Infatti non è ancora usato 😃
Confermo il vendorID e productID che è uguale a quello postato da pablo66:
3G Modem vendorID: 0x12d1; productID: 0x14fe
Huawei e353s-2 H3G
ecco dai, almeno se riesci a far andare quella siamo ragionevolmente sicuri che vada anche la Wind 😛
Ci sono riuscito, ho creato il file .bin e funziona perfettamente.
Ho dovuto installare xp in una partizione …
Ho mandato il file alla TP-LINK e all’amministratore del forum.
PS. Sto usando il firmware di giugno ma sicuramente funziona anche con quello di aprile.
hai dovuto disattivare CD e SD o dare altri comandi AT?
No no, ho fatto tutto con il software tp-link.
Aggiunto nel primo messaggio delle discussioni ufficiali, grazie 😉
