TL-MR3220 System Log
Time = 2000-01-01 0:06:46 407s
H-Ver = MR3220 v1 00000000 : S-Ver = 3.12.8 Build 110418 Rel.43954n
L = 192.168.1.1 : M = 255.255.255.0
W1 = DHCP : W = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
1st day 00:00:04 OTHER INFO System started
1st day 00:00:08 DHCP NOTICE DHCP server started
1st day 00:00:08 SECURITY INFO PPTP Passthrough enabled
1st day 00:00:08 SECURITY INFO L2TP Passthrough enabled
1st day 00:00:08 SECURITY INFO IPSEC Passthrough enabled
1st day 00:00:08 SECURITY INFO FTP ALG enabled
1st day 00:00:08 SECURITY INFO TFTP ALG enabled
1st day 00:00:08 SECURITY INFO H323 ALG enabled
1st day 00:00:09 SECURITY INFO RTSP ALG enabled
1st day 00:00:29 DHCP NOTICE DHCPS:Recv REQUEST from 00:24:81:3D:05:19
1st day 00:00:29 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:00:31 DHCP NOTICE DHCPS:Send ACK to 192.168.1.163
1st day 00:00:35 DHCP NOTICE DHCPS:Recv INFORM from 00:24:81:3D:05:19
1st day 00:00:40 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:00:53 3G INFO Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:00:54 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:01:06 3G INFO Switch modem mode with the 1 command in the file usb_modeswitch.conf
1st day 00:01:14 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:01:15 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:01:22 DHCP NOTICE DHCPS:Recv REQUEST from 00:21:00:7F:67:BA
1st day 00:01:23 DHCP NOTICE DHCPS:Send ACK to 192.168.1.137
1st day 00:01:27 DHCP NOTICE DHCPS:Recv INFORM from 00:21:00:7F:67:BA
1st day 00:02:00 DHCP NOTICE DHCPS:Recv INFORM from 00:24:81:3D:05:19
1st day 00:02:02 3G INFO Main interface_index[0] = -1
1st day 00:02:02 3G INFO Vice interface_index[1] = 1
1st day 00:02:02 3G INFO Vice interface_index[2] = 3
1st day 00:02:02 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:02:04 3G INFO Line 944: ATZ
1st day 00:02:04 3G INFO Line 944: OK
1st day 00:02:04 3G INFO Line 944: AT+CGMM
1st day 00:02:04 3G INFO Line 953: MT191UP
1st day 00:02:04 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:02:04 3G INFO get_modem_info_file 140 getModemParamByScript return valid type = 1
1st day 00:02:04 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:02:07 3G INFO Line 944: ATZ
1st day 00:02:07 3G INFO Line 944: OK
1st day 00:02:07 3G INFO Line 944: AT+CSQ
1st day 00:02:07 3G INFO Line 978: +CSQ: 7,99
1st day 00:02:07 3G INFO Line 944: AT+CGMR
1st day 00:02:07 3G INFO Line 944: MT191UP.TIM.FW.B05
1st day 00:02:07 3G INFO Line 944: OK^M
1st day 00:02:07 3G INFO Line 944: Serial connection established.
1st day 00:02:07 3G INFO Line 944: Serial link disconnected.
1st day 00:02:07 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:02:07 3G INFO get_modem_info_file 155 getModemParamByScript return valid type = 1
1st day 00:02:07 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:02:09 3G INFO Line 944: ATZ
1st day 00:02:09 3G INFO Line 944: OK
1st day 00:02:09 3G INFO Line 944: AT+CPIN?
1st day 00:02:09 3G INFO Line 1024: +CPIN: READY
1st day 00:02:09 3G INFO Line 944: AT+CGMR
1st day 00:02:09 3G INFO Line 944: MT191UP.TIM.FW.B05
1st day 00:02:09 3G INFO Line 944: OK^M
1st day 00:02:09 3G INFO Line 944: Serial connection established.
1st day 00:02:09 3G INFO Line 944: Serial link disconnected.
1st day 00:02:09 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:02:09 3G INFO get_modem_info_file 170 getModemParamByScript return valid type = 1
1st day 00:02:09 3G INFO get_modem_info_file 185 Return chip type = 1
1st day 00:02:09 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:02:09 3G INFO USB modem is ready
1st day 00:02:10 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:02:10 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB1 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:02:13 OTHER WARNING Username and password are successfully updated
1st day 00:02:14 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:17 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:20 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:23 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:26 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:29 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:32 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:35 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:38 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:39 DHCP NOTICE DHCPS:Recv REQUEST from 00:21:00:7F:67:BA
1st day 00:02:39 DHCP NOTICE DHCPS:Send ACK to 192.168.1.137
1st day 00:02:41 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x410d0e8]
1st day 00:02:44 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:02:44 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB3 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:02:44 DHCP NOTICE DHCPS:Recv INFORM from 00:21:00:7F:67:BA
1st day 00:02:47 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:02:47 3G NOTICE 3G Modem connecting error, please check the dial number and APN.
1st day 00:02:49 3G INFO mobileCmdReq 310 mobileFormatCmd error
1st day 00:02:50 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:02:50 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB1 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:02:59 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:02:59 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB3 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:03:02 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:03:02 3G NOTICE Modem switchs failed, reset the 3G modem, please wait.
1st day 00:03:04 3G INFO mobileCmdReq 310 mobileFormatCmd error
1st day 00:03:11 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:03:22 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:03:22 DHCP NOTICE DHCPS:Recv INFORM from 00:24:81:3D:05:19
1st day 00:03:36 3G INFO Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:03:38 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:03:49 3G INFO Switch modem mode with the 1 command in the file usb_modeswitch.conf
1st day 00:03:57 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:03:57 DHCP NOTICE DHCPS:Recv INFORM from 00:21:00:7F:67:BA
1st day 00:03:58 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:04:45 3G INFO Main interface_index[0] = -1
1st day 00:04:45 3G INFO Vice interface_index[1] = 1
1st day 00:04:45 3G INFO Vice interface_index[2] = 3
1st day 00:04:45 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:04:47 DHCP NOTICE DHCPS:Recv REQUEST from 00:21:00:7F:67:BA
1st day 00:04:47 DHCP NOTICE DHCPS:Send ACK to 192.168.1.137
1st day 00:04:47 3G INFO Line 944: ATZ
1st day 00:04:47 3G INFO Line 944: OK
1st day 00:04:47 3G INFO Line 944: AT+CGMM
1st day 00:04:47 3G INFO Line 953: MT191UP
1st day 00:04:47 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:04:47 3G INFO get_modem_info_file 140 getModemParamByScript return valid type = 1
1st day 00:04:47 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:04:50 3G INFO Line 944: ATZ
1st day 00:04:50 3G INFO Line 944: OK
1st day 00:04:50 3G INFO Line 944: AT+CSQ
1st day 00:04:50 3G INFO Line 978: +CSQ: 8,99
1st day 00:04:50 3G INFO Line 944: AT+CGMR
1st day 00:04:50 3G INFO Line 944: MT191UP.TIM.FW.B05
1st day 00:04:50 3G INFO Line 944: OK^M
1st day 00:04:50 3G INFO Line 944: Serial connection established.
1st day 00:04:50 3G INFO Line 944: Serial link disconnected.
1st day 00:04:50 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:04:50 3G INFO get_modem_info_file 155 getModemParamByScript return valid type = 1
1st day 00:04:50 3G INFO Line:926 cmd: modem_scan -d /dev/ttyUSB1 -f “chat -S -V -f /tmp/script” > /tmp/modem_info 2>&1^M
1st day 00:04:50 DHCP NOTICE DHCPS:Recv INFORM from 00:21:00:7F:67:BA
1st day 00:04:52 3G INFO Line 944: ATZ
1st day 00:04:52 3G INFO Line 944: OK
1st day 00:04:52 3G INFO Line 944: AT+CPIN?
1st day 00:04:52 3G INFO Line 1024: +CPIN: READY
1st day 00:04:52 3G INFO Line 944: AT+CGMR
1st day 00:04:52 3G INFO Line 944: MT191UP.TIM.FW.B05
1st day 00:04:52 3G INFO Line 944: OK^M
1st day 00:04:52 3G INFO Line 944: Serial connection established.
1st day 00:04:52 3G INFO Line 944: Serial link disconnected.
1st day 00:04:52 3G INFO getModemParamByScript 1099 Chip type = 1
1st day 00:04:52 3G INFO get_modem_info_file 170 getModemParamByScript return valid type = 1
1st day 00:04:52 3G INFO get_modem_info_file 185 Return chip type = 1
1st day 00:04:52 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x0037
1st day 00:04:52 3G INFO USB modem is ready
1st day 00:04:52 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:04:52 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB1 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:04:56 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:04:59 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:02 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:05 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:08 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:11 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:14 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:17 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:20 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:23 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xef235b1]
1st day 00:05:26 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:05:26 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB3 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:05:30 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:05:30 3G NOTICE 3G Modem connecting error, please check the dial number and APN.
1st day 00:05:32 3G INFO mobileCmdReq 310 mobileFormatCmd error
1st day 00:05:33 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:05:33 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB1 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:05:42 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:05:42 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB3 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:05:57 3G INFO mobileGenCfgFile 112 Get chip type: 1
1st day 00:05:57 3G NOTICE Modem switchs failed, reset the 3G modem, please wait.
1st day 00:05:59 3G INFO mobileCmdReq 310 mobileFormatCmd error
1st day 00:06:07 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:06:18 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:06:31 3G INFO Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:06:33 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x2000
1st day 00:06:44 3G INFO Switch modem mode with the 1 command in the file usb_modeswitch.conf
