Salve a tutti.
ho acquistato un router 3220 per utilizzarlo con la zte k3806-z marcata vodafone
il modem 3g è nella lista dei compatibili, ho aggiornato il fw con successo a
Firmware Version:
3.12.20 Build 120309 Rel.54030n
Hardware Version:
MR3220 v1 00000000
però continuo ad avere il problema
3G USB Modem: Unknown Modem. Please configure the modem on Modem Settings manually.
ho anche provato a vedere i binari e ho addirittura provato a caricare i binari anche se erano per il 3420, ma non ha funzionato
idee?
questo è il mio ultimo log
Firmware Version:
Hardware Version:
MR3220 v1 00000000
idee?
Codice:
Index Time Type Level Log Content
130 1st day 00:01:38 PPP ERROR User request
129 1st day 00:01:38 PPP INFO sent [LCP TermAck]
128 1st day 00:01:38 PPP WARNING LCP down
127 1st day 00:01:38 PPP ERROR LCP down
126 1st day 00:01:38 PPP INFO rcvd [LCP TermReq]
125 1st day 00:01:37 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0 dns1=0.0.0.0 dns3=0.0.0.0]
124 1st day 00:01:37 PPP INFO rcvd [PAP AuthAck "Icera PPP - Password Verified OK"]
123 1st day 00:01:37 PPP INFO sent [LCP code=0xc]
122 1st day 00:01:37 PPP INFO sent [PAP AuthReq user="" password=(hidden)]
121 1st day 00:01:37 PPP INFO sent [LCP Ack mru=1600 auth=pap magic=0xe3565da5 asyncmap=0x0]
120 1st day 00:01:37 PPP INFO rcvd [LCP Req mru=1600 auth=pap magic=0xe3565da5 asyncmap=0x0]
119 1st day 00:01:37 PPP INFO rcvd [LCP Ack mru=1480 asyncmap=0x0 magic=0xd334658c]
118 1st day 00:01:37 PPP INFO sent [LCP Rej pcomp accomp]
117 1st day 00:01:37 PPP INFO rcvd [LCP Req mru=1600 auth=pap magic=0xe3565da5 asyncmap=0x0 pcomp accomp]
116 1st day 00:01:37 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0xd334658c]
115 1st day 00:01:36 3G WARNING Modem scanner can not get usable interfaces, please reinsert the 3G Modem.
114 1st day 00:01:36 3G INFO Main interface_index[0] = -1
113 1st day 00:01:33 3G INFO Run 3G dial cmd: pppd /dev/ttyACM1 115200 connect "chat -s -v -f /etc/ppp/conn-s
112 1st day 00:01:33 PPP NOTICE Standard authentication.
111 1st day 00:01:31 3G INFO USB modem is ready
110 1st day 00:01:31 3G INFO 3G Modem vendorID: 0x19d2; productID: 0x1015
109 1st day 00:01:31 3G INFO get_modem_info_file 185 Return chip type = 1
108 1st day 00:01:31 3G INFO get_modem_info_file 170 getModemParamByScript return valid type = 1
107 1st day 00:01:31 3G INFO getModemParamByScript 1100 Chip type = 1
106 1st day 00:01:31 3G INFO Line 944: Serial link disconnected.
105 1st day 00:01:31 3G INFO Line 944: Serial connection established.
104 1st day 00:01:31 3G INFO Line 944: OK^M
103 1st day 00:01:31 3G INFO Line 944:
102 1st day 00:01:31 3G INFO Line 944: P4 rev: CL401862 with 0 lcal change(s).
101 1st day 00:01:31 3G INFO Line 944: EAGLE_R1.5.14
Time = 2000-01-01 0:02:06 127s
H-Ver = MR3220 v1 00000000 : S-Ver = 3.12.20 Build 120309 Rel.54030n
L = 192.168.1.1 : M = 255.255.255.0
3G : 3G = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
