<3>[ 468.520000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 468.930000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 468.950000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 469.370000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 469.390000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 469.920000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 469.940000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 470.360000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 470.380000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 470.800000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 470.820000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
<3>[ 471.380000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
prima scrive questo:
<6>[ 423.430000] usb 1-1: USB disconnect, device number 2
<5>[ 423.430000] sd 0:0:0:0: [sda] Synchronizing SCSI cache
<6>[ 423.460000] sd 0:0:0:0: [sda]
<4>[ 423.460000] Result: hostbyte=0x01 driverbyte=0x00
<6>[ 459.470000] usb 1-1: new high-speed USB device number 3 using ar71xx-ehci
<6>[ 459.620000] scsi1 : usb-storage 1-1:1.0
<5>[ 460.620000] scsi 1:0:0:0: Direct-Access SEAGATE ST3250820A 3.AA PQ: 0 ANSI: 2
<5>[ 460.630000] sd 1:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
<5>[ 460.640000] sd 1:0:0:0: [sda] Write Protect is off
<7>[ 460.640000] sd 1:0:0:0: [sda] Mode Sense: 53 00 00 08
<5>[ 460.640000] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
<6>[ 460.670000] sda: sda1
<5>[ 460.700000] sd 1:0:0:0: [sda] Attached SCSI disk
<3>[ 471.400000] EXT4-fs (sda1): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
Questo è invece quello che dice il router
si, credo si stia riferendo ai punti di montaggio… \mnt \opt e \jffs
— /dev/sda
Block device, size 232.9 GiB (250059350016 bytes)
DOS/MBR partition map
Partition 1: 232.9 GiB (250059317248 bytes, 488397104 sectors from 63)
Type 0x83 (Linux)
Ext4 file system
UUID CA8CCDA4-08F2-4908-B827-BECF5D19537A (DCE, v4)
Last mounted at “/share/external/sdu1”
Volume size 232.9 GiB (250059317248 bytes, 61049638 blocks of 4 KiB)
Status: Not mounted
