<6>[ 424.670000] usb 1-1: new high speed USB device using ar71xx-ehci and address 3
<4>[ 424.680000] Resetting; Code: 01
<6>[ 425.230000] scsi2 : usb-storage 1-1:1.0
<6>[ 425.230000] scsi3 : usb-storage 1-1:1.1
<4>[ 425.570000] Resetting; Code: 01
<4>[ 426.470000] Resetting; Code: 01
<4>[ 427.370000] Resetting; Code: 01
<5>[ 427.760000] scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
<5>[ 427.770000] scsi 3:0:0:0: Direct-Access HUAWEI SD Storage 2.31 PQ: 0 ANSI: 2
<5>[ 427.800000] sd 3:0:0:0: [sda] Attached SCSI removable disk
<4>[ 427.810000] sr0: scsi-1 drive
<7>[ 427.820000] sr 2:0:0:0: Attached scsi CD-ROM sr0
<4>[ 428.190000] Resetting; Code: 01
<4>[ 429.090000] Resetting; Code: 01
<6>[ 429.840000] ar5416LoadNF: delay for NF loading is not enough, usually rx in progress!
Freeing node: 76:ea:3a:db:1f:66
ic->ic_cwm.cw_width :0, ic->ic_cwm.cw_extoffset: -1
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
Resetting; Code: 01
ifconfig ath0 down
ifconfig ath0 up
br0: port 3(ath0) entering disabled state
br0: port 3(ath0) entering learning state
br0: topology change detected, propagating
br0: port 3(ath0) entering forwarding state
Ignore the current channel 6
find_best_11ng_centerchan: found best center chan: 11
ic->ic_cwm.cw_width :1, ic->ic_cwm.cw_extoffset: -1
Sending cwmmode action frame to ff:ff:ff:ff:ff:ff
